Transmission issue
140,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ANT73
I was driving my car, I reached a slowdown on the highway. As slowdown cleared, I accelerated. The car revved as if it was on neutral. I put car in park, turned car off. Turned it back on and put it in drive. Same revving, not moving. Wouldn't move in reverse either. No check engine light, no message from car.
I got the car towed to the shop, shop tells me it's a bad sensor (I forget the name of the sensor). They are going replace the sensor, change the transmission fluid. $500.00.
I get a call from them today, saying they changed the part and fluid, and now the check engine light is on and it's telling them i need a new transmission.
Is this normal? Can the possibly have damaged the transmission while changing fluid or the sensor? Am i dealing with a bad mechanic?
Nov 25, 2020 at 7:49 AM
  • 110,248 POSTS
First, low fluid may have caused the issue, and I'm not sure what sensor they were referring to. However, I have never seen a code indicating to replace the transmission.
Is it possible for you to get the code from them so I can check into exactly what it is?
Nov 25, 2020 at 10:39 AM
ANT73
Thanks for reply. I will get as much info as possible on Friday. Happy thanksgiving.
Nov 25, 2020 at 10:45 AM
  • 110,248 POSTS
You're very welcome. Try to get specific diagnostic trouble codes. With them, I can research the problem, possible causes, and possible repairs.
Hopefully, it will be something less expensive than a transmission.
You have a nice Thanksgiving as well.
Nov 25, 2020 at 12:36 PM
