Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Civic
Drivetrain
Transmission
Filter
Location
Transmission filter location
2007 HONDA CIVIC
234,783 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
FASOROTI FEMI
MEMBER
1 POST
Where is the transmission filter located in the car listed above LX model?
Feb 27, 2018 at 7:21 PM
SEVAG P
Experienced Mechanic
transmission fluid filter located inside engine compartment under the air cleaner assembly, check the picture below.
also check the procedure how to check the ATF fluid level.
let us know if you need more help. thank you.
Images (Click to enlarge)
Jan 22, 2021 at 5:35 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
