It sounds like you are having a problem with the TCU (transmission control unit). I've attached a diagnostic chart below to help test.Hope this helps and thanks for again for using 2CarPros.
Image (Click to enlarge)
Nov 15, 2019 at 8:52 AM
SANDY555
MEMBER
My hot battery cable was extremely loose is there a way to reset the TCM.
Nov 15, 2019 at 10:32 PM
✓Experienced Mechanic
You can just clear the codes and it should reset. here is a video to show you how:
Had the code cleared.shifted good ..but when I started the car back up again had the problem again
Nov 16, 2019 at 3:15 AM
DANNY L
Hello again.
By just clearing the code if there is a fault the condition will keep showing up as in the case here until the repair is completed.It sounds like you are having an issue with the TCM (transmission control module) I will re-attach the diagnostic procedure again below.Hope this helps and thanks again for using 2CarPros.
Nov 16, 2019 at 8:18 PM
SANDY555
MEMBER
Okay, thanks for your help. trying to fix it myself as my husband is disabled and don't have the money to put it in the shop.
Nov 16, 2019 at 9:01 PM
Nov 17, 2019 at 2:50 AM
SANDY555
MEMBER
Okay, will sure let you know.
Nov 17, 2019 at 3:17 AM
DANNY L
Hello again,
Hoping it just could be a wiring issue. However, just to prepare you a new transmission control module from a Kia dealership is $940.00. Let us know what you find out.Thanks again for using 2CarPros.
Nov 17, 2019 at 7:10 AM
SANDY555
MEMBER
Thank you for all your help. It will be a while before I can afford one of those.
Nov 17, 2019 at 7:12 AM
SANDY555
MEMBER
We found the hot battery cable end was loose on the battery yesterday.
Nov 17, 2019 at 7:14 AM
DANNY L
Hello again,
After you tighten the cable let us know if the symptom returns.If so, please use the transmission control module diagnostic chart I've attached previously.Hope this helps and thanks again for using 2CarPros.
