transmission is in limp mode
ROBERTOWENS63
how do you reset the code to get the transmission out of the limp mode? it takes off in high gear.
Apr 23, 2013 at 11:10 AM
it is in limp mode for a reason, re setting does nothing to fix the issue. you need someone to check it out, determine the failure, repair it and then re set the code with a scan tool
Apr 23, 2013 at 11:30 AM
ROBERTOWENS63
thank you Roy, that is what i was thinking.
Apr 23, 2013 at 11:46 AM
DOCHAGERTY
  • 9,606 POSTS
Rechipping the EGS is the solution
May 7, 2013 at 10:45 AM
