Do you have a transmission installation checklist?
123 MILES • 7.3L • V8 • 4WD • AUTOMATIC
AB AUTOMOTIVEREPAIR TRANSMISSIONS
  • 107 POSTS
Would you guys happen to have a printable Transmission Installation Checklist that includes everything from flywheel, dowels, filling fluid to cooler and lines? Figure if I'd find a good one anywhere, you'd be the place to have it.
(Preferable a 1 for all type of list)
Thanks a bunch.
(This is what I have so far...)
Feb 12, 2021 at 3:15 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately no, we don't have a form like that. The best thing I can think of is to go online and look for automotive type printable forms. Hope this helps and thanks for using 2CarPros.
Feb 12, 2021 at 1:27 PM
  • 107 POSTS
This is what I came up with incase anyone else needs a template. :)
Feb 13, 2021 at 3:32 AM
STEVE W.
  • 15,415 POSTS
I think the issue here is that most of us who spin steel sort of know what steps to use and many times assume that others also know to do those steps. Can really be a trap if you don't though. For instance even something like "Change out the spark plugs" can get interesting if it's a vehicle that requires the intake manifold be removed to access them.
Even worse are the times where you do an interchange and then discover that the OE pulled a switch mid year and the parts are actually not compatible but there is no mention of this in any service info, That can be fun if you go through and swap in the replacement and it all bolts up perfect, then doesn't work!! (Yes Chrysler I'm speaking of you specifically !)
Feb 14, 2021 at 5:45 AM
DANNY L
  • 5,648 POSTS
Hey Steve W.
You've never had fun until doing spark plug changes until you been on a 1997-2005 E-series Ford van. Like laying under the hood? Or better yet, Since your a Chrysler guy a Hemi Ram truck V8 with 16 spark plugs while doing it in the rain... Just sayin...
Feb 14, 2021 at 2:19 PM
STEVE W.
  • 15,415 POSTS
Those are fun. My favorites were some of the early 1970's cars, like the big old Pontiacs with the 400 that you had to pull the front tires and go in through the wheel wells to get at the plugs. Or the Ford Super Duties where step one was to pull the cab off for access.
Feb 14, 2021 at 8:53 PM
  • 107 POSTS
Steve, I keep telling my boss that... he gets annoyed after the umpteenth time of the same question.. but I have to remind him that to him this is 2nd nature, for me, it's more like 6th and for the public it's foreign so sometimes we have to hold their hand.
Feb 14, 2021 at 11:30 PM
DANNY L
  • 5,648 POSTS
Hello again.
That is what I did for my self-employed auto repair business. I found an automotive printable online form for a work repair sheet. I printed it out and just make color copies when needed. Hope this helps and thanks again for using 2CarPros.
Danny-
Feb 15, 2021 at 10:45 AM
  • 107 POSTS
Danny, that is great for the shop automotive repair side.. did that a couple of years ago, haven't used it once since we are transmission rebuilding owner/operated, but what I need is like a: hold your hand, this is how you install a transmission template... what I have for the converter is pretty detailed now.. still bet they'll mess it up here and there.. SMH
P.S. check out the skilled art... those are actual photos from our customers broken pump photo to sketch... Love that program.
Mar 5, 2021 at 3:29 AM
STEVE W.
  • 15,415 POSTS
Don't even need to look, biggest converter issue, not seating it into the pump properly and not shimming it if needed to ensure the ears are seated properly. Result, one trashed pump. Next would be not flushing or replacing the cooler after an internal failure that tossed shrapnel around, that one applies to oil/trans/PS coolers and AC systems equally though.
Mar 5, 2021 at 7:59 AM
DANNY L
  • 5,648 POSTS
Nice!
I actually had a pump failure on a 4L60 after 1400 miles on New Years Day.. I didn't do the rebuild myself..... The warranty wasn't covered-- Company disappeared and I had to start all over.. Luckily the idiot company didn't bother to show up and take my original as a core !
Mar 5, 2021 at 12:29 PM
  • 107 POSTS
Aw, that stinks... here, we're with them until the end. until that vehicle is running smooth.. it sucks that there are so many frauds out there representing the whole.
Mar 8, 2021 at 9:48 PM
  • 107 POSTS
Steve, you got it! :) If only we could hold their hand, lol.
Mar 8, 2021 at 9:50 PM
  • 110,248 POSTS
I noted that you haven't replied in a couple of days. I was wondering if you got what was needed and if any progress has been made. We're interested in knowing.
Mar 11, 2021 at 6:57 AM
  • 107 POSTS
We've been attaching the red stop signs to each rebuild and giving them the torque converter instruction sheet, initialing their invoice that they confirm we've given it to them, so far so good.. been working on another project past couple of days, today getting into a 518. Fun times. Thanks for checking in.
Mar 11, 2021 at 9:48 PM
  • 110,248 POSTS
Thanks for getting back to us. Good luck with the 518. LOL
Take care of yourself and feel free to come back anytime in the future. You're always welcome here.
Mar 12, 2021 at 10:02 AM
