Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Civic
Trouble Codes
P Codes (Powertrain)
P0700 - P0799
P0718
codes P0717 and P0718?
2009 HONDA CIVIC
190,000 MILES • 1.8L • 2WD • AUTOMATIC
JOPARIZOM
MEMBER
1 POST
Which is a fault with the input/turbine speed sensor. Where is this sensor and how do I replace it?
May 18, 2020 at 4:20 AM
Experienced Mechanic
P0717 - Input shaft speed sensor failure. No signal
P0718 - Input shaft speed sensor failure. Intermittent signal.
I attached the testing for the p0717 code is you want to run through that to find the issue. I also attached the location and replacement information.
Let me know if you need more info and we can go from there. Thanks
Images (Click to enlarge)
May 18, 2020 at 8:36 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
