Transmission sticks between third and overdrive when warmed up
1995 CHEVROLET SILVERADO
404,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MATTHEWDHAMMOND
Truck runs good cold, shifts good, no problem. After it gets warm when going up hills, passing even when giving little more throttle it seems to slow like it sticks between third and overdrive. when I let off gas it will shift into overdrive and resume okay.
Even then when I take off at red lights it hesitates between gears.
Dec 18, 2016 at 8:42 PM
HMAC300
  • 48,601 POSTS
have a transmission professional scan for codes it may be a wiring issue , valve body or TCM.
Dec 18, 2016 at 11:32 PM
MATTHEWDHAMMOND
Thanks, that was my next move. I have read up on where the wiring harness could be the problem.
Dec 19, 2016 at 1:22 AM
