Transmission has lost forward moving gears
2002 CHEVROLET CAVALIER
98,000 MILES • 2.4L • 4 CYL • AUTOMATIC
63 NOVA SS
Transmission goes in reverse good and solid; car moves great. Won't go forward at all.
Feb 12, 2022 at 12:34 AM
If the transmission goes in reverse, then more than likely the fluid is okay, but we always need to check and make sure the level and condition is okay.
Here is a guide that will help with this. Plus, the condition of the fluid will help figure out what may be happening.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Next, we should check the pressure in the unit and find out if they are correct.
I suspect the pressure is going to be low in drive which means we have internal issues and would need to drop the pan.
Please see the process below and let us know what the pressure is, and we can go from there.
Thanks
Feb 13, 2022 at 3:58 AM
