Transmission has no drive but has reverse
100,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BEN DE SOTO
Vehicle goes into reverse and functions completely perfect. I put it in drive it will idle forward but no matter how much gas I give it won't go any faster. I added more fluid same problem. I had the transmission replaced same problem.
Aug 25, 2019 at 6:09 AM
Good morning,
Did you use a new or used transmission?
Did you have the TCM flashed? It could be a programming issue.
Is the check engine light on? If it is, do you know the code?
Aug 25, 2019 at 8:53 PM
