I recently replaced the solenoid pack the transmission fluid and filter i can drive it but it shifts hard on every gear at about 2500 rpm
Jan 3, 2016 at 3:04 AM
HMAC300
✓Experienced Mechanic
did it do that before you worked on it? a hard shift doesn't hurt it anyhow was it acting up is why you replaced solenoids and fluid in the first place.
Jan 3, 2016 at 3:22 AM
RUBEN541X13
MEMBER
Yes now I get all the gears but with a really hard shifting on first and second and the other gears I have to go to a really high rpm to get them to engage
Jan 3, 2016 at 7:35 AM
HMAC300
if fluid you removed was dark brown or black then this trans will not last long as it was losing a clutch pak or seal more than likely . Have a trans guy look at it
Jan 3, 2016 at 10:57 PM
RUBEN541X13
MEMBER
My fluid wasn't brown or black and it didn't smell burnt
