transmission grinds when placing into reverse
145,000 MILES • 2.6L • 4 CYL • 4WD • MANUAL
CHARLES SLANE
I had the clutch replaced after getting truck back it would grind when shifting into reverse. I took the truck back they replaced clutch slave cylinder however it still does it. I bleed the system starting at clutch master cylinder had good pedal then real week same thing with slave cylinder. Could the problem be with the clutch master cylinder. The only issue I had was clutch was slipping prior to putting he shop.
Jul 23, 2014 at 12:44 PM
HMAC300
  • 48,601 POSTS
it may be the master not keeping good pressure on slave or not bled right. reverse has no schyncro so it will or could grind going into reverse.
Jul 23, 2014 at 10:52 PM
CHARLES SLANE
The transmission was fine before I took it to the shop. The clutch was slipping. I feel it's the master cylinder for clutch. I won't take it back to the shop.
Jul 24, 2014 at 5:51 AM
HMAC300
  • 48,601 POSTS
try adjusting clutch pedal height as well when you put in new master shold be7.3-7.7" from floor or 185-195mm
Jul 24, 2014 at 6:10 AM
CHARLES SLANE
Ok thanks. It's a funny thing when I drove it today it seemed to be doing fine no issue when shifting into reverse. Thanks for your help.
Jul 24, 2014 at 6:17 AM
