Transmission going out
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLMILLER41914
It feels like the transmission is slipping. The car feels like it jerks back when driving down the road. I thought that maybe it could be the spark plugs and wires. Someone mentioned maybe try some fuel injector cleaner. Help!
Feb 5, 2018 at 11:51 PM
  • 110,248 POSTS
We have to start simple. First, if the check engine light is on, have the computer scanned. If it is not on, check the fluid to make sure it is clean and full. Keep in mind, if the plugs are bad and causing a misfire, the check engine light should be on. Check those two things and let me know what you find.
Feb 8, 2018 at 10:17 AM
STEVE W.
  • 15,418 POSTS
When was the last time it was given a tune up? Is the check engine light on? Even if it is not I would take it to a shop and have them scan it for codes in the engine and transmission controllers. There are a lot of codes that will not turn the light on or require multiple events over a set time period before the light comes on, one of those could give you more information to look at. In the mean time check the level and condition of the transmission fluid. You want to see it full and the fluid to be a nice red or light brown color. Black, gritty, burnt smelling oil is a bad sign and would likely mean a rebuild or replacement of the transmission.
Feb 8, 2018 at 10:19 AM
CLMILLER41914
There is no check engine light on. The fluid is good not burnt. So maybe check plugs and wires. I am also thinking catalytic converter. I have lost fuel efficiency.
Feb 8, 2018 at 11:10 AM
  • 110,248 POSTS
Plugs, catalytic converter. all should have turned the check engine light on. Try scanning the system just to see if there is something stored.
Feb 8, 2018 at 11:12 AM
STEVE W.
  • 15,418 POSTS
Converter would not cause transmission slippage or jerking. Misfires would and a slipping clutch pack in the transmission could cause it as well as the loss of mileage. To check it you need to have a scan tool that can read the trans controller so you can see if the apply timing and rpm's as the transmission shifts are okay.
Feb 8, 2018 at 11:41 AM
CLMILLER41914
Thank you all for your responses. It was a simple fix. I put in fuel injector cleaner (three days ago) and the jerking has stopped.
Feb 8, 2018 at 9:25 PM
STEVE W.
  • 15,418 POSTS
If that did the trick then I would consider doing a top cylinder cleaning as you likely have carbon build up at the injector tips as well. The cleaning would remove that mess.
Feb 9, 2018 at 3:23 AM
  • 110,248 POSTS
That's good news. Let us know if it starts again.
Feb 10, 2018 at 12:34 PM
