Transmission reverse gear not engaging
129,250 MILES • 6 CYL • 4WD • AUTOMATIC
FRANK JOSEPH
transmission gearbox not engaging reverse gear.
Jan 18, 2022 at 2:40 PM
Good morning,
If you have normal forward gears and no reverse gear, it is most likely a failure inside the transmission.
I would drain the fluid, add new fluid and inspect the fluid to be sure there is no metal in the fluid or chunks of material. A band and a clutch are used for reverse so it could be either one causing the issue.
Jan 18, 2022 at 7:46 PM
