Transmission flush
130,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MIGHTYARK1987
I want to flush the transmission in my truck.
And my question is, do I use one of the cooling lines that are connected to the drivers side of the radiator? If so which one is the sending line and which one is the return line? My other question is: is this the right way to flush this transmission?
Aug 9, 2018 at 4:30 AM
STEVE W.
  • 15,370 POSTS
You would be better off doing a "spill and fill". Basically removing the pan and draining it, then changing the filter. Then refill with new fluid. Reason being that unless you have a pump to push the fluid through the system you will need to keep dumping fluid into the transmission fast enough to keep the pan full so the pump can pull it through the filter.
Neither method exchanges all the fluid however, nor does a power flush normally.
There will always be "old" fluid mixed in with the new. With the pan method you get to change the fluid and the filter. You will not get the fluid in the converter but if that is a big worry you could install a pan with a drain and just change the fluid a few times after you change the filter.
Mar 24, 2021 at 6:22 AM
