Transmission Fluid Temperature Sensor
90,900 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KELLY273020
My car started shifting hard and the check engine light came on. I took it to auto zone and had the code read. It came up as p0711 Transmission Fluid Temperature Sensor "A" Circuit Range/ Performance. I have searched all over for a Diagram with the location of the sensor for my cars motor and there is none. Can you tell me where the particular sensor would be located?
Jul 6, 2018 at 6:10 AM
Good afternoon.
It is inside the cover for the valve body. I attached the procedure and pictures for you to view.
Removal
1. Remove the battery and the battery tray.
2. Remove the under cover (A).
Tightening torque:
7.8 - 11.8 N.m (0.8 - 1.2 kgf.m, 5.8 - 8.7 lb-ft)
imageZoom/Print
3. Replace new gasket and the plug after draining the automatic transaxle fluid by removing the drain plug.
4. Remove the valve body cover (B) and eyebolt (A).
Tightening torque:
(A) 34.3 - 44.1 N.m (3.5 - 4.5 kgf.m, 25.3 - 32.6 lb-ft)
(B) 13.8 - 14.7 N.m (1.3 - 1.5 kgf.m, 9.4 - 10.8 lb-ft)
Caution:
Always replace the gasket of the eyebolt use new one whenever loosening eyebolt.
imageZoom/Print
5. Disconnect the oil temperature sensor connector (A).
imageZoom/Print
6. Remove the oil temperature sensor (A) after removing a bolt.
Tightening torque:
9.8 - 11.8 N.m (1.0 - 1.2 kgf.m, 7.2 - 8.7 lb-ft)
imageZoom/Print
Installation
1. Installation is the reverse of removal.
Note:
After replacement or reinstallation procedure of the valve body assembly, must perform procedures below.
- Continue to apply liquid gasket at application points at the valve body cover with 2.5mm (0.0984in.) thickness.
Liquid gasket Part name :
Three bond 1281B or LOCTITE FMD-546(P/N : UM010CH046) or equivalent
- Adding automatic transaxle fluid.
Jul 6, 2018 at 6:21 AM
