Transmission fluid/motor oil
185,000 MILES
I_HATE_MY_CAR
  • 8 POSTS
I have a 95 buick park avenue with a 3.8L. Over the past 3 months I have had to add about 6qts of transmission fluid because of low dipstick readings. During the same period, I have noticed my oil level increasing regularly. Yesterday out of curiosity, I drained oil out to reduce the oil level & ended up draining out 5qts of oil before it got back to a regular level. I have not noticed any fluid puddles(oil or tranny fluid) under my car & I suspect that my tranny fluid is somehow leaking into my crankcase. Is this possible & how do I resolve this? Also, what damage can occur to the engine if this mixture of tranny fluid & oil is actually occurring? Thank you. Charlie.
Apr 19, 2013 at 11:42 PM
the only fluid in contact is the coolant from the cooler in the radiator.
did you check the coolant for trans fluid???
Apr 19, 2013 at 11:53 PM
I_HATE_MY_CAR
  • 8 POSTS
Yes, I checked both in the radiator cap & reservoir and it look a clear green with no oil sheen on top.
Apr 20, 2013 at 1:53 AM
since there is no connection, the trans fluid has to be leaking out from somewhere. did you have a shop check for the leak????
Apr 20, 2013 at 5:44 AM
I_HATE_MY_CAR
  • 8 POSTS
I have not & there are no signs of a leak or oily buildup under the car or in the engine compartment. So there is no chance the tranny fluid could be getting into my motor oil in any way? As I mentioned, I had to drain 5 quarts of fluid from my engine just to get it to down to a normal level.
Apr 20, 2013 at 6:28 AM
just thinking about something. see if there is a vacuum valve in the front of the trans with a vacuum line on it. if there is remove it and see if it has fluid in the line. if it does, then thats our issue.
Apr 20, 2013 at 6:32 AM
I_HATE_MY_CAR
  • 8 POSTS
Yes there is traces of fluid in the line and they are swelled up/saturated & flimsy. So, do I need to replace the "vacuum valve"?
Apr 20, 2013 at 8:06 AM
its called a modulator valve for the trans
Apr 20, 2013 at 8:08 AM
I_HATE_MY_CAR
  • 8 POSTS
Thank you! I was wondering if you could help me with another challenge with the same vehicle? I wont start or crank over. I charged up the battery for 5hrs & it wouldn't charge past 90% so I put the charger in start mode & it still wound not crank or even click when I turned the key. I took out the starter & bench tested it with the same battery & it cranked over just fine. I re-installed & did a continuity test from the positive at the battery to the starter solenoid, had a good reading. When I do turn the key on (not cranking), my dash gauge only reads 9-10v. I also trace the small wire on the starter to the neutral safety switch & noticed the mounting/adjustment screws were very loose. Any suggestions?
Apr 20, 2013 at 8:37 AM
try moving the shifter up and down and see if it starts
Apr 20, 2013 at 8:47 AM
I_HATE_MY_CAR
  • 8 POSTS
Yes, I did try that & in neutral as well. I cant even get the starter to make a click noise. Could it be related to why I only get a 9-10v reading on my dash? I put a load tester on my batt & it was on the bottom edge of good.
Apr 20, 2013 at 9:15 AM
I_HATE_MY_CAR
  • 8 POSTS
This morning I cranked over the engine with a remote starter switch with the key in the on/run position. It cranked over normally, revved up for a second & stopped, I repeated this several times with the same results. I checked all the fuses inside & out and they are all good. Any suggestions?
Apr 21, 2013 at 2:08 AM
sure could, i suspect a bad battery to start. then check voltage at the little wire on the starter solenoid while in the start position to verify power
Apr 21, 2013 at 2:24 AM
I_HATE_MY_CAR
  • 8 POSTS
Hello Roy, I took my battery to have it tested, it was weak so I replaced it. I hooked up a multimeter to the small wire at the starter while my daughter turned the the key to start, it read zero voltage. Also, I am still only getting a 9-10v reading on my dash gauge with the key in the on position, it has always read 12.5 before these issues started. please advise. Thank you.
Apr 21, 2013 at 10:19 AM
could be either a bad ignition switch, neutral safety switch or wiring issue
Apr 21, 2013 at 11:06 AM
