I have heard it is wise to change out the transmission fluid after a certain number of miles have been driven. However, I realize that a fluid exchange only replaces a relatively small amount of the original transmission fluid whereas a transmission flush should replace all of the fluid. However, since this an older vehicle (2007 Toyota Camry) I am somewhat hesitant to attempt a flush as I understand that it can actually be harmful to older transmissions. But since the mileage on this car is only 58,700 miles I need to know if a fluid exchange would still be preferable to a transmission flush.
Apr 16, 2024 at 8:50 AM
