Radiator Replacement Small leak of transmission fluid
150,000 MILES • 2.4L • 5 CYL • AWD • AUTOMATIC
TABLETALK
  • 15 POSTS
Small leak of transmission fluid where the transmission hose connects to the radiator.
Mechanic states that radiator must be replaced (radiator is free of charge, as it is under warranty), but labor is about 5.5 hours.
The connection is part of the radiator, and cannot be removed.
1. Can a sealant (silicone?) be used to seal the leak?
2. Would that cancel the warranty if radiator needs to be replaced down the road?
Thanks.
Feb 21, 2017 at 11:47 PM
  • 55,817 POSTS
It sounds like there is a defect in the metal fitting which will need to be replaced to fix. Sealer cannot be used. Sorry,
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Feb 24, 2017 at 6:03 AM
TABLETALK
  • 15 POSTS
Thanks Ken. I put some JB Weld epoxy on it. So far it is not leaking. If that doesn't work I may have to replace the radiator. Is there a repair video on this site to instruct me how to do that?
Feb 27, 2017 at 7:37 PM
  • 31,937 POSTS
we can get you step by set instruction from Mitchell 1 data base, just post the car details and a VIN is also a big help to locate this info for you.
Feb 27, 2017 at 7:54 PM
  • 55,817 POSTS
Hey TABLETALK,
Nice work on the JB weld I hope it will work for you but if not here are some guides and instructions on how to replace the radiator, you will need to discharge the air conditioner.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
Please let us know happens.
Best, Ken
Feb 28, 2017 at 3:13 AM
