Transmission fluid in the radiator
110,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JAYMELEE28
Hello everyone. I'm not well versed on cars so ber with me.
I've had some issues with my Mazda3 engine dropping or sputtering when accelerating from a stopped position. It did fine when I was on the highway though. It also seemed to shake a bit but, other than that, no other indications that something was wrong..
I initially thought it was the fuel pump again. We had it replaced back in March for similar performance issues. Took it back to the dealership last week and came back with a diagnosis of internal coolant leak where the transmission fluid and coolant are mixing. Also got a lovely a quote for $6,844.00 worth of repairs.
$817.00 for radiator replacement.
$327.00 for replacement of thermostat.
$5,553.00 for replacement of transmission.
$75.00 for coolant.
$162.00 for transmission fluid.
I had my boyfriend check it out and the coolant reservoir it's this pink color so seems like this is definitely the case from what I've seen online.
My question is, is it really necessary to replace the transmission or was the dealership just tacking on a transmission replacement unnecessarily? I'm reading I could probably get by with a radiator replacement and a transmission flush. Is this true?
Nov 6, 2019 at 5:15 AM
CARADIODOC
  • 34,414 POSTS
It seems to me the mileage and age are too low to be having this type of problem. The exception would be if the coolant is still original. It needs to be replaced every two years to prevent a build-up of harmful acid that attacks the metal parts in the cooling system. There are water pump lubricant, seal conditioner, and corrosion inhibitor additives in antifreeze to prevent these problems, but it's those additives that wear out in about two years.
All of the charges you listed seem too high, so I'd recommend getting a second diagnosis and opinion from an independent repair shop. We know a new radiator is needed, along with new antifreeze, but if this just occurred recently, you will likely get by with a transmission flush. When antifreeze finds its way into engine oil or transmission fluid, it will melt the soft first layer of engine bearings and transmission bushings. Either of those will lead to a major failure, but that damage doesn't occur right away. When engine oil or transmission fluid gets into the cooling system, it will slowly rot the rubber radiator and heater hoses from the inside, so this would be a good time to have the cooling system flushed too.
The common maintenance procedure for cooling systems is to drain and refill the system every two years. Many mechanics prefer to perform a more thorough flush the first time this maintenance is done to clean out the casting sand that is usually stuck inside from the engine manufacturing process. After that, drain and refills are sufficient if there are no other problems.
Every manufacturer also lists a recommended service interval for automatic transmissions. Most of the time we do a simple drain and fill which removes about half of the old fluid. The filter gets replaced at the same time. The new fluid has enough additives, so it's not necessary, or even possible, to get all the old fluid out. That is what the more-involved transmission flush is for. That is what is needed here to be sure all the antifreeze has been washed out. The flush also cleans everything out of the cooler lines that run from the transmission to the radiator.
You haven't listed any symptom that would point to the need to replace the thermostat. For the price you were quoted for that repair, the new thermostat must be made of solid gold, or this car model is extremely difficult to work on. A lot of models today require special transmission fluid formulations, and some of them are pretty expensive. Other than the cost of the transmission fluid, I suspect you're going to get a much more reasonable estimate from an independent repair shop.
Nov 6, 2019 at 7:51 AM
