Transmission fluid change
135,000 MILES • 3.8L • 6 CYL • 2WD
ALEXTTT
  • 59 POSTS
I changed out my transmission fluid and i had metal shavings by the megnet. I done several transmission fluid changes on my other car and never seen it like this.
Apr 19, 2020 at 7:28 AM
Good afternoon.
The metal you see is normal wear and tear. There will always be some metal on the magnet. That is why they put a magnet on the pan to start.
Apr 19, 2020 at 7:36 AM
ALEXTTT
  • 59 POSTS
Thank you for your response.
If i wanted to get the old fluid out of the torgue converter. Should i drive it another 200 miles and drop the pan?
Apr 19, 2020 at 7:51 AM
You could do that, yes.
Or you could take it somewhere and have them do fluid exchange, not a flush. That will get all the fluid out of the converter.
Apr 19, 2020 at 7:56 AM
