Transmission fluid change
2003 TOYOTA HIGHLANDER
255,000 MILES • 3.0L • 6 CYL • 2WD
BRUSCIAJ
Hi, just watched your video on doing the transmission fluid change on the Toyota highlander, fantastic videos super in depth. My question is, I've had the car for a long time and quite a bit of miles; I was told that doing a fluid change would be a bad idea because all of the gunk is helping to lubricate it, but as of recently it's starting to shift pretty rough. In your opinion, would I be better trying to change the fluid, or should I give up on the car and wait until it gives out? It's currently my daily driver.
Jun 7, 2022 at 11:19 AM
  • 110,244 POSTS
The theory is based on how dirty the transmission fluid is. If it is extremely contaminated, new fluid will flush it out and become dirty itself very quickly. This can lead to it slipping. Simply, you have removed a portion of the debris that was helping with friction between the clutch plates. The new fluid does have a detergent in it, so it will start cleaning.
However, in most cases, it doesn't cause this to happen. If it is shifting hard, chances are there is a restriction in the filter or transmission causing the line pressure to lower. That can eventually lead to the clutches failing.
How dirty is the fluid in it presently? If you were to describe its color, what would it be, black, red, or dark red? Was the fluid ever changed in the past?
Jun 7, 2022 at 1:51 PM
BRUSCIAJ
I have never had the fluid changed while I've had the car. It's at 250,000. I got it at 170,000 and I don't know if the previous owner changed either. The fluid is darker fading red color.
Jun 8, 2022 at 2:48 AM
  • 110,244 POSTS
If you can still see a reddish tint in the fluid, you should be fine to service it. When it is black and no longer translucent, that is a concern.
Let me know how things go for you.
Jun 8, 2022 at 1:58 PM
