transmission fluid backward compatible
160,000 MILES • 3.0L • 6 CYL
JAYHHR1
I have the car listed above, that calls for Dexron III, but many shops no longer carry III. only Toyota T IV, after calling a Toyota dealer, they told me that IV is backward compatible, but other online boards, say not so. basically IV, is a upgraded version of the III according to who, you talk to.
Feb 1, 2019 at 1:53 PM
Good morning,
As far as the fluid, yes, you can use a better fluid but never worse.
Dex 4 is approved by Toyota but you need to get all the fluid out of the transmission not just the pan. The torque converter holds around five quarts.
By the way, Dexron 3 is still available at parts stores as well as at Toyota dealerships as well.
Change Vehicle Bookmarks Library Request Conversion Calculator Technician's Reference - Collision
Search vehicle information
Community 16 Create Quote
2000 Toyota Camry LE Sedan V6-3.0L (1MZ-FE)
Fluid Types and Capacities
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Specifications Fluid Types and Capacities
FLUID TYPES AND CAPACITIES
Fluid Types
ATF TYPE: .................... ATF D-II or DEXRON III (DEXRON II (r)
CAPACITY:
Dry Fill: .................... 8.0 liters ()8.5 US qts, 7.0 Imp. qts)
Drain and Refill: .................... 3.9 liters (4.1 US qts, 3.4 Imp. qts)
Capacities
CAPACITY:
Dry Fill: .................... 8.0 liters (8.5 US qts, 7.0 Imp. qts)
Feb 2, 2019 at 12:01 AM
