Transmission fluid
2006 CHRYSLER PT CRUISER
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
Do I have to use Mopar Atf+4 for the transmission after fluid and filter replacement? Or I can use any other Atf+4 brand as Castrol Transmax ATF+4® Transmission Fluid (1 Quart)?
Jun 11, 2018 at 12:09 PM
  • 110,244 POSTS
Chrysler has their own specific type. However, there are other manufacturers which produce a comparable replacement that is fine. Keep in mind, someone made it for Chrysler. Just make sure what you buy indicates it can be used in place of the original type.
Jun 11, 2018 at 1:02 PM
ZEMORZEMOR
  • 486 POSTS
About Castrol Transmax ATF+4® Transmission Fluid it says Technologically advanced, full synthetic formulation provides superior transmission life
engineered with superior base oils to ensure superb low and high temperature performance
Certified and approved for all Chrysler, Hyundai, and Mitsubishi cars and trucks that require ATF+4®, Mopar ATF+3®, ATF+2®, ATF+2 Type 7176®, or ATF+®
Industry Specifications and OEM Approvals: Meets or Exceeds Chrysler ATF+4® requirements; ATF+4® approved and licensed by Chrysler LLC (License Number 40630033).
Jun 11, 2018 at 1:05 PM
  • 110,244 POSTS
According to that information, it will be fine. It specifically indicates it can replace ATF+4.
Jun 11, 2018 at 1:15 PM
ZEMORZEMOR
  • 486 POSTS
The AC compressor making noise when engaging after I replaced AC accumulator, refiled the Freon and added 2 oz of oil. How much oil the compressor needs to have Nippodenso 10s17 and what Pag ? oil . Do I need to evacuate the system again and check the oil in it?
Jun 13, 2018 at 6:47 AM
ZEMORZEMOR
  • 486 POSTS
I am asking you a different topic in here because I want second opinion from you. I asked this question already in this website.
Jun 13, 2018 at 6:48 AM
ZEMORZEMOR
  • 486 POSTS
The AC compressor making noise when engaging after I replaced AC accumulator, refiled the Freon and added 2 oz of oil. How much oil the compressor needs ( Nippodenso 10s17) and what Pag? Oil.
Jun 13, 2018 at 8:23 PM
RENEE L
  • 1,260 POSTS
Hello ZEMORZEMOR.
In order for the site to properly categorize your new/different issue question please post it here: https://www.2carpros.com/questions/new
One of our experts will answer it shortly.
Thank you,
Renee
Admin
Jun 14, 2018 at 8:07 AM
