What type of transmission fluid?
150,000 MILES • 3.0L • V6 • 2WD • MANUAL
DENISDALIY
Transmission fluid.
Mar 14, 2025 at 7:47 AM
STEVE W.
  • 15,418 POSTS
That truck uses API G-L4 aka 75W-90 or 80W-90 Should be around 4.5 pints if you drain it. To change it you pull the drain plug at the bottom, then use the fill plug to add the oil in.
Mar 14, 2025 at 10:49 AM
