Transmission fluid
249,000 MILES • 6.0L • 6 CYL • 2WD • AUTOMATIC
VEGATITA55
Are all ATF transmission fluids the same? I that what is requested when purchasing?
Nov 7, 2017 at 6:24 AM
WRENCHTECH
  • 20,758 POSTS
Definitely not. There are about a dozen different fluids and you can only use the one the manufacturer requires.
For your vehicle it is Type ATF T-IV
There are some synthetic brands that can be used to cover many different type. Just make sure it meets those requirements.
Nov 7, 2017 at 6:38 AM
TITA VEGA
I believe it is Dexron +IV.
Nov 7, 2017 at 6:43 AM
WRENCHTECH
  • 20,758 POSTS
It is exactly what I posted. That came from the service manual.
Nov 7, 2017 at 6:45 AM
TITA VEGA
Okay, thank you.
Nov 7, 2017 at 6:46 AM
