Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Tacoma
Drivetrain
Transmission
Fluid
Transmission fluid
2003 TOYOTA TACOMA
249,000 MILES • 6.0L • 6 CYL • 2WD • AUTOMATIC
VEGATITA55
MEMBER
1 POST
Are all ATF transmission fluids the same? I that what is requested when purchasing?
Nov 7, 2017 at 6:24 AM
WRENCHTECH
Experienced Mechanic
Definitely not. There are about a dozen different fluids and you can only use the one the manufacturer requires.
For your vehicle it is Type ATF T-IV
There are some synthetic brands that can be used to cover many different type. Just make sure it meets those requirements.
Nov 7, 2017 at 6:38 AM
TITA VEGA
MEMBER
I believe it is Dexron +IV.
Nov 7, 2017 at 6:43 AM
WRENCHTECH
It is exactly what I posted. That came from the service manual.
Nov 7, 2017 at 6:45 AM
TITA VEGA
MEMBER
Okay, thank you.
Nov 7, 2017 at 6:46 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
