Transmission fluid
129,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JOEALANIZ07
Can you help me find out what kind of transmission fluid my truck uses?
Sep 1, 2019 at 1:01 AM
Below is the spec for the fluid.
Automatic Transmission Fluid
Ford Part Name
- Motorcraft MERCON LV ATF
Ford Part Number
- XT-10-QLV
Ford Specification
- MERCON LV
NOTE: Automatic transmissions that require MERCON LV should only use MERCON LV fluid. Use of any fluid other then the recommended fluid may cause transmission damage.
Mar 23, 2021 at 5:11 AM
