Add Transmission Fluid?
189,545 MILES • 1.6L • 4 CYL • 2WD • MANUAL
AZDANNO04
  • 378 POSTS
Isn’t there a spot to add transmission other than the driver side front tire being removed and adding it from there?
Jun 15, 2023 at 10:23 AM
  • 55,721 POSTS
It says there is a dip stick,
1. Start engine, allow transaxle fluid to reach 158-176° F.
2. Position vehicle on level surface, then set parking brake.
3. With engine idling, brake pedal depressed, move shift lever through all positions.
4. Remove transaxle dipstick, wipe clean, then replace.
5. Remove dipstick again, check fluid at HOT level.
6. Refer to Lubricant Data for capacities. See: Fluid - A/T > Capacities
Fluid Recommended .................... Dexron(R)-III Automatic Transmission Fluid
Please check this guide as well.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Please go over this guide and get back to us.
Jun 16, 2023 at 2:41 AM
AZDANNO04
  • 378 POSTS
I thought it took Dextron VI.
Jun 20, 2023 at 1:23 PM
AZDANNO04
  • 378 POSTS
Manual transmission 1.6 liter.
Jun 20, 2023 at 1:24 PM
  • 55,721 POSTS
My bad, I gave info for an auto transmission. here is a guide to help show you how to check the fluid and the fluid type as well.
Fluid Type
Manual .................... SAE 75W-90 GL-4 or equivalent
Automatic .................... DEXRON-III auto trans. or equivalent
Capacity
Manual 5 Speed .................... 2.6 liters (2.7 qts)
Automatic (drain and refill)
3-Speed .................... 2.5 liters (2.6 qts)
4-Speed (includes Differential) .................... 3.1 liters (3.3 qts)
https://www.2carpros.com/articles/how-to-service-a-manual-transmission
and
https://youtu.be/WqDixYeqslI
Jun 21, 2023 at 3:18 AM
