Hi, I hope you all can help me. I am in the process of replacing the flywheel.
I removed both CV Axles.
I removed both Front Drive Shaft Flanges.
I see that the flanges are spring loaded
and I see a split clip at the top of the spring assembly.
I see a groove near the base of spring assembly.
Do I have to push the flange under spring pressure into transmission, so the split clip goes into the groove I mentioned above?
See images.
See images.
Apr 22, 2022 at 7:23 AM
