How to change the transmission filter?
160,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
VEND
How do you change the transmission filter in the vehicle listed above?
Aug 31, 2024 at 7:24 AM
  • 55,628 POSTS
This transmission has a fluid screen not a filter which is non serviceable, so it is known as a dump and fill. Here is a guide to help you step by step with instructions in the images below for your car:
Ford Part Name
- Mercon V Automatic Transmission Fluid
Ford Part Number
- XT-5-QM
- XT-5-QMC (US)
- CXT-5-LM12 (Canada)
Ford Specification
- MERCON V
Note: Using any transmission fluid other than those that meet the recommended specification may cause internal transmission damage. Check out the images (below). Let us know what you find.
Sep 1, 2024 at 4:45 AM
