Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Kia
Amanti
Drivetrain
Transmission
Filter
Location
Transmission filter location
2005 KIA AMANTI
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DILL-11
MEMBER
Where is the transmission filter located?
Feb 7, 2019 at 3:14 AM
Experienced Mechanic
Good afternoon,
There are two locations for the filter.
One is external which means it is in the pan. when you drop the pan, then it will be there.
If it is internal, then the transmission has to be removed and split apart.
Feb 7, 2019 at 3:32 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
