Transmission fill plug size
197,000 MILES • 4 CYL • 2WD • MANUAL
JIGGIDYJ10
  • 6 POSTS
I am wondering the size of the transmission fill plug and drain plug. I want to make sure I have metric if it needs to be done with them. The fill plug is stripped so I was going to use an extractor socket to break it loose. Thanks!
Jun 30, 2018 at 12:23 PM
DANNY L
  • 5,648 POSTS
Hello Danny here.
I will find out and get back to you. Danny-
Jul 1, 2018 at 5:25 PM
JIGGIDYJ10
  • 6 POSTS
Any luck? Thanks!
Jul 2, 2018 at 9:44 AM
DANNY L
  • 5,648 POSTS
Hello again.
Unfortunately I was not able to get an actual size however, Here is the Toyota dealership part number: Fill plug- part number #9034118006 ($11.31) and drain plug- part number #9034118057 ($18.16). There might be a possibility that your local auto parts store can cross reference these numbers to find out the size. Hope this helps! Let me know if you have any further questions and again thanks for using 2CarPros.
Danny-
Jul 2, 2018 at 10:01 AM
JIGGIDYJ10
  • 6 POSTS
That information is perfect. Thank you so much for looking into this and helping me out!
Jul 2, 2018 at 10:13 AM
