1989 Toyota Pickup Transmission will not shift out of park
1989 TOYOTA PICKUP
82,103 MILES • 6 CYL • FWD • AUTOMATIC
STEW EASTMAN
Vehicle has been idell for about 2-3 months because of dead battey. After I installed the new battery it started fine without a problem but then I could not shift out of park.
Jun 7, 2010 at 8:19 AM
2CARPRO JACK
  • 11,533 POSTS
See if the brake lights work and use a test light to see if the CIG fuse is good.According to Mitchell there is a shift-lock system that may be giving you trouble and it uses that fuse
Jun 7, 2010 at 3:52 PM
