Transmission fault, car will not move
130,000 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
FERRAL CEASAR
Transmission fault. I am having a transmission fault and car will not move. do you know of any independent Porsche mechanic that I can have the car delivered to?
Mar 29, 2019 at 9:25 AM
JOETECHPRO
  • 705 POSTS
Hey FERRAL CEASAR,
Where are you located?
I would advise a quick Google search will give you a list of Porsche specialists in your area.
It may be more effective for the diagnosis work to be done by a Porsche dealer.
You can then get quotes for the repair from specialists/independents.
Do you have access to a scanner?
The guide below is for check engine light but you will use the same process to check for transmission codes:
If you can provide us with the fault codes we can give you a bit more information on the potential issues and some checks you can do yourself.
Regards, Joe
Mar 29, 2019 at 11:51 AM
