transmission fault
2009 CHEVROLET TRAVERSE
90,000 MILES • AUTOMATIC
SAED75
  • 5 POSTS
I have Chevrolet traverse 2009 with transmission problems , fault codes P0752 , 989 , 877,
I want to replace the valve body with TCM & speed sensors.
My question: is reprogramming required after installation?
Jan 3, 2016 at 2:56 AM
yes, the new tcm requires re programming.
what lead you to replace all the sensors???
Jan 3, 2016 at 3:06 AM
SAED75
  • 5 POSTS
Thanks for quick response..
I'm getting gear stuck sometimes from 2nd to 3rd..with check engine light on and fault P0752 (solenoid A stuck) problem goes if restart the car it move on normal.
Later on got other faults of 989 , 877 about oil pressure circuits.
Also delay 2-3 sec when shifting from N to D with small jump.
Do u think if replace the whole valve body should resolve it?
Jan 3, 2016 at 4:27 AM
no, the oil pressure codes concern me. it may be you have an internal failure in the front pump. I would try by changing the oil/filter and see if that makes a difference
Jan 3, 2016 at 4:35 AM
SAED75
  • 5 POSTS
Since am replacing the solenoids and valve body anyway ..will i have access to the pump ? ie ..can be checked or replaced easily if required?
Jan 3, 2016 at 4:47 AM
in order to replace the pump the transmission has to be removed, the side pan has to be removed, channell plate and then access to the pump. it is a vane style pump.
Jan 3, 2016 at 5:00 AM
