Hi, 2018 Nissan Kicks 16L, Vin: 3N1CP5CP4JL469405 Engine: HR16-869094N
This car was taken for a light accident repair and stayed in the garage for around one year, repaired and left there by the owner (My sister).
The time we start the car normal starting no issue and because of the period the car stayed there the car hardly moving (very slow), we suggest to change the transmission oil but still moving very slowly.
took it for a specialist Nissan technician who checked it and said this the transmission failure need to be changed and a he said, changed the transmission with 4 transmission including the changing some new parts inside the transmission and did the programming too for several valve body.
The car now moving as it should but still the transmission have a serious issue when shifting into second or third gear, or downshifting from third to second as you slow down you can feel a strong shudder.
The technician said he did everything but unfortunately this what he can reach to.
Now the car moving good but only this strong shudder, please help.
Thanks
Ramzi
Thanks
Ramzi
Nov 11, 2026 at 6:53 PM
