Transmission failure, will not shift into drive or reverse when the engine is cold?
175,000 MILES • 3.8L • 4 CYL • 2WD • AUTOMATIC
NABEEL JAWAD
Hello everybody,
The transmission of my vehicle listed above Sport fails to shift into D or R when the engine is still cold, only a ticking sound is heard. Once the temperature is normal it can shift to D or R. Any idea of the reason for that?
Jul 31, 2023 at 4:28 AM
  • 55,721 POSTS
Yes, if the transmission fluid is low, it will cause this issue.
here is a guide to help you check the fluid level:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
And this guide may help as well:
https://www.2carpros.com/articles/how-to-diagnose-and-fix-an-automatic-transmission-that-wont-engage-gears
Please go over these guides and get back to us.
Jul 31, 2023 at 10:32 AM
