Transmission exchange
150 MILES • V6
CHARLES HARBIN
My 1994 4x4 standard cab has a bad 5 spd transmission .
Can I use a 1994 2wd 5 spd transmission?
If I pull the tail shaft off the 2wd transmission can I mount the transfer case on it and will this work ? Or is this not an option?
Dec 16, 2019 at 3:55 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately no, It will not work. The output shalfts on a 2wd and 4wd are different lengths.You will have to use a 4wd transmission.Hope this helps and thanks for using 2CarPros.
Dec 16, 2019 at 5:36 PM
CHARLES HARBIN
Hi Danny , thanks for your response . I figured it was worth asking and now I know it wont work . Thanks again
Dec 19, 2019 at 3:39 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Hope you will use us again for any future automotive questions. Thanks again for using 2CarPros.
Danny-
Dec 19, 2019 at 6:49 PM
