My car sounds like you have a flat tire on right hand side but do not.
Mar 23, 2018 at 12:25 AM
✓Experienced Mechanic
Did you check for something in the tire? if it is a hum or a growl, probably a bearing starting to fail, get a mechanic to do a test drive to confirm this as you do need to hear these noises to be sure of a diagnosis on some occasions.
