Fluid is leaking from plug I have a new washer but it leaks. I have attached a video of a possible crack but not certain it’s 100 percent.
Videos (Click to enlarge)
Aug 15, 2021 at 1:53 PM
✓Experienced Mechanic
I see things that look like cracks, but I don't think they are. It's hard to tell from a video.
Try this: Get brake cleaner and clean everything off so it's dry. Then refill the transmission to see if you can locate the leak. Hopefully, this will help to identify where the leak is originating. I don't think anything is cracked, but it is possible.
If it is still coming from the drain plug, let me know.
I will watch for your reply.
Aug 15, 2021 at 3:28 PM
FARR2007
MEMBER
Almost certain it’s from drain plug. what do I do?
Oct 21, 2021 at 8:32 PM
Did you replace the drain plug gasket/o-ring? See pic below. Let me know if that was replaced.
Image (Click to enlarge)
Oct 22, 2021 at 12:10 PM
FARR2007
MEMBER
I replaced the metal crush washer yes.
Oct 27, 2021 at 11:56 AM
If you replaced the washer/gasket and it still leaks, inspect the area around the plug for evidence of cracks. Also, spray everything down so it's dry and clean. Then confirm the leak is from the drain plug. If there are cracks causing it, you should be able to see the fluid seeping through them.
Oct 27, 2021 at 12:58 PM
FARR2007
MEMBER
how tight do I tighten new crush washer and plug?
Oct 28, 2021 at 3:57 PM
If you look below, there are two pics that include the torque specifications. I'm not sure if the vehicle has a 4 cylinder or a 6.
The first pic shows the torque for a V6 and the second pic is for the four cylinder.
Let me know if this helps.
Images (Click to enlarge)
Oct 29, 2021 at 10:51 AM
FARR2007
MEMBER
I still can’t get this transmission plug to stop leaking on my car.
Nov 5, 2021 at 9:24 AM
If you replaced the gasket and torqued it to specification, there has to be a crack we are missing. You have confirmed the leak is from the drain plug, correct? I know you were originally questioning possible cracks.
Also, when you replaced the metal crush washer, was it only metal? You may want to try a nylon or composite washer/gasket in place of the crush washer.
Nov 5, 2021 at 1:08 PM
FARR2007
MEMBER
I don’t know for sure if this is the crack you are referring to, but I have attached pics. please advise me on how I can repair?
Nov 5, 2021 at 4:51 PM
FARR2007
MEMBER
So, went out to check vehicle and the bottom half of transmission bolt hole where crack looked to be is now completely broke off and, on the ground, is there a transmission pan for this car or does it come apart to where I can just replace the side where bolt goes in?
Nov 5, 2021 at 10:22 PM
There isn't a pan. As far as the crack, that is part of the case. What I would do is this. First, you need to find someone that can weld aluminum and have that part welded back into place. Then they make "pan savers" that you can use to seal it. (See pic 1 below)
To replace that portion of the case, the transmission needs to be taken apart. I would at least try to do it this way.
I wish I had an easy answer. Please let me know if I can help you in any way.
See pic below.
Nov 6, 2021 at 2:04 PM
FARR2007
MEMBER
I don’t know anyone who can weld and could I use an expansion plug?
Nov 6, 2021 at 2:09 PM
You could try something like that. My biggest concern is it would come loose or if the housing has other cracks, the expansion may cause it to break more.
Let me know if I can help in any way.
Nov 7, 2021 at 9:19 AM
FARR2007
MEMBER
Without tearing the transmission apart what are my best options?
Nov 7, 2021 at 10:54 AM
I would want the broken part welded back to the housing and then use a pan saver. I wish I had a better answer, but there really isn't.
Nov 7, 2021 at 2:06 PM
FARR2007
MEMBER
What the heck is a pan saver?
Nov 7, 2021 at 2:10 PM
It's what I mentioned a few posts back. I reattached the pic below. If you weld it back together, either you will need to drill and re-tap the threads or use a pan saver. It basically works like a toggle bolt. See pic below.
If the weld is done properly, the absolute best thing is to drill and re-tap the threads and use an oversized pan bolt, but the pan saver will work as well.
