Transmission does not shift into second gear?
187,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
NITHINCOBALT
  • 6 POSTS
After an oil change, the power steering goes off and the speedometer doesn't work and hard/ late transmission. So, I checked under the hood to see the grounding to TCM. When I grounded the TCM properly the power steering is back on but not the speedometer and when I try to hard shift the gear by going it up to 6,000 RPMs there is a hard shift but now again the power steering goes out and message pops up. Please help.
Aug 11, 2023 at 6:04 PM
  • 55,746 POSTS
This sounds like the TCM needs to be replaced or the grounds are bad, you can get a preprogrammed unit by searching Google or Ebay. Here is how the job is done. Here is a guide to help you test the grounds and the TCM wiring diagrams below so you can see which wires to test:
Aug 12, 2023 at 8:28 AM
