Transmission does not shift
175,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
RICHARD MANNAS
Had to replace intake manifold gaskets due to water leak. Now engine races over 3000 rpm when started but does drop down to 1500 to 2000 rpm after it warms up. Transmission hangs in gear until you remove your foot from the accelerator pedal for a second or two, then if you put more than a feathers weight on it it will down shift again. I have checked for manifold leaks but could not find any this time.
R. Mannas
Mar 9, 2018 at 3:05 AM
Good afternoon.
It does sound like you have a vacuum leak. Check along where the head meets the manifold. Remove the oil fill cap and see if you feel pressure pushing out or vacuum.
as far as the transmission, the TPS sensor on the throttle body is the critical sensor for transmission shift points. check the voltage at idle. it should be .5 volts. then as the pedal is pushed, the voltage should rise to around 4.8 volts. do this with key on engine off.
Mar 9, 2018 at 4:55 AM
AUSTIN.JENNINGS
  • 5 POSTS
hi, i have a problem with my transmission not shifting out of first gear. i changed the speed sensor and all four solenoids. i changed out the transmission fluid too, but still not shifting. so with that all being said what could cause the problem?
Dec 28, 2020 at 2:10 AM (Merged)
Good evening
Is the check engine light on??
The throttle position sensor on the throttle body is what controls the shifting of the transmission. It monitors the voltage and based on that the PCM sends a command to the shift solenoids to open and close.
AUSTIN.JENNINGS
  • 5 POSTS
yes, check engine light is on. so what would i need to change now?
Okay, first you need to have the codes read. you can take it to a parts store and they will read it for free.
then once we know the code, we need to look at the possibilities and follow a flow chart to determine the failure. codes never identify bad parts, just failed systems.
AUSTIN.JENNINGS
  • 5 POSTS
okay, i should be able to get the codes after work tomorrow and I will post them on here for you. i appreciate the help Roy.
AUSTIN.JENNINGS
  • 5 POSTS
po425-fuel tank pressure.
po155- ho2s heater performance bank 2 sensor 1.
po452-fuel tank pressure(ftp) sensor circuit low voltage.
po740-tcc enable solenoid circuit-electrical.
po785-3-2 shift solenoid circuit-electical.
po1860-tcc pwm solenoid circuit-electical.
740 code
Circuit Description:
The torque converter clutch (TCC) solenoid valve is an electrical device that is used with the torque converter clutch pulse width modulation (TCC PWM) solenoid valve in order to control TCC apply and release. The TCC solenoid valve attaches to the transmission case assembly extending into the pump cover. The TCC solenoid valve receives ignition voltage through the OFF/ON/START voltage circuit. The powertrain control module (PCM) controls the solenoid by providing the ground path on the TCC solenoid valve control circuit. The PCM monitors the throttle position sensor voltage, the vehicle speed, and other inputs in order to determine when to energize the TCC solenoid valve.
When the PCM detects a continuous open, short to ground or short to power in the TCC solenoid valve circuit, then DTC P0740 sets. DTC P0740 is a type B DTC.
Conditions for Running the DTC
^ The system voltage is 10 - 18 volts.
^ The engine speed is greater than 450 RPM for 5 seconds.
^ The engine is not in fuel cutoff.
Conditions for Setting the DTC
DTC P0740 sets if one of the following conditions occurs for 5 seconds:
Condition 1
The PCM commands the solenoid ON and the voltage feedback remains high, B+.
Condition 2
The PCM commands the solenoid OFF and the voltage feedback remains low, 0 volt.
Action Taken When the DTC Sets
^ The PCM illuminates the malfunction indicator lamp (MIL) during the second consecutive trip in, which the Conditions for Setting the DTC are met.
^ The PCM inhibits TCC engagement.
^ The PCM inhibits 4th gear if the transmission is in hot mode.
^ The PCM freezes shift adapts from being updated.
^ The PCM records the operating conditions when the Conditions for Setting the DTC are met. The PCM stores this information as Freeze Frame and Failure Records.
^ The PCM stores DTC P0740 in PCM history during the second consecutive trip in, which the Conditions for Setting the DTC are met.
Conditions for Clearing the MIL/DTC
^ The PCM turns OFF the MIL during the third consecutive trip in, which the diagnostic test runs and passes.
^ A scan tool can clear the MIL/DTC.
^ The PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without an emission-related diagnostic fault occurring.
^ The PCM cancels the DTC default actions when the ignition switch is OFF long enough in order to power down the PCM.
Diagnostic Aids
With the TCC engaged, the TCC slip speed should be -20 to +50 RPM.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
4. This step tests for voltage to the solenoid.
5. This step tests the ability of the PCM and wiring to control the ground circuit.
7. This step tests the resistance of the TCC solenoid valve and the automatic transmission (AT) wiring harness assembly.
785 code
Circuit Description
The 3-2 shift solenoid (SS) valve assembly is a normally-closed, 3-port, on/off device that controls the 3-2 downshift. The solenoid attaches to the control valve body within the transmission. The solenoid receives ignition voltage through the OFF/ON/START voltage circuit. The powertrain control module (PCM) controls the solenoid by providing a ground path on the 3-2 shift solenoid valve control circuit. During a 3-2 downshift, the 2-4 band applies as the 3-4 clutch releases. The PCM varies the timing between the 3-4 clutch release and the 2-4 band apply, depending on the vehicle speed and the throttle position.
When the PCM detects a continuous open, short to ground or short to power in the 3-2 SS valve assembly circuit, then DTC P0785 sets. DTC P0785 is a type B DTC.
^ The engine speed is greater than 450 RPM for 5 seconds. The engine is not in fuel cutoff.
DTC P0785 sets if one of the following conditions occurs for 5 seconds:
Condition 1
Condition 2
The PCM commands the solenoid OFF and the voltage feedback remains low, 0 volts.
^ The PCM commands a soft landing to third gear.
^ The PCM commands maximum line pressure.
^ The PCM stores DTC P0785 in PCM history during the second consecutive trip in, which the Conditions for Setting the DTC are met.
^ The PCM cancels the DTC default actions when the fault no longer exists and/or the ignition switch is OFF long enough in order to power down the PCM.
Test Description
The item numbers below refer to the step numbers on the diagnostic table.
4. This step tests the ability of the PCM to control the solenoid.
5. This step tests for voltage to the solenoid.
6. This step tests the ability of the PCM and the wiring to control the ground circuit.
8. This step measures the resistance of the automatic transmission (AT) wiring harness assembly and the 3-2 SS valve assembly.
CHRISTOPHER JARMAN
  • 9 POSTS
I just rebuilt my transmission put in a new third and fourth clutch pack. replaced the third fourth piston seal and all the seals checked the sunshell it was fine but replaced it anyway. put it all back together shifts into third but I have to let go of the gas to get it to shift and seems it is losing pressure and slips back out. I don't know what is going on. any help would be appreciated!
1860 code
Circuit Description
The torque converter clutch pulse width modulation (TCC PWM) solenoid valve controls the fluid acting on the converter clutch valve. The converter clutch valve controls the TCC application and release. The solenoid attaches to the control valve body within the transmission. The solenoid receives ignition voltage through the OFF/ON/START voltage circuit. The powertrain control module (PCM) controls the solenoid by providing a ground path on the TCC PWM solenoid valve control circuit. Current flows through the solenoid coil according to the duty cycle, percentage of ON and OFF time. The TCC PWM solenoid valve provides a smooth engagement of the TCC by operating during a duty cycle percent of ON time. When the PCM detects a continuous open, short to ground or short to power in the TCC PWM solenoid valve circuit, then DTC P1860 sets. DTC P1860 is a type B DTC.
^ The PCM commands first gear.
^ The TCC duty cycle is less than 10 percent or greater than 90 percent.
DTC P1860 sets if one of the following conditions occurs for 5 seconds:
Condition 1
The PCM commands the solenoid ON, 90 percent, and the voltage feedback remains high, B+.
Condition 2
The PCM commands the solenoid OFF, 0 percent, and the voltage feedback remains low, 0 volt.
^ The PCM stores DTC P1860 in PCM history during the second consecutive trip in, which the Conditions for Setting the DTC are met.
Test Description
7. This step tests the resistance of the TCC PWM solenoid valve and the automatic transmission (AT) wiring harness assembly.
  • 55,748 POSTS
Do you have any check engine lights on? if so this guide can help us. also when you did the repair did you get the seals in correctly for the servo and drums? Check out the diagrams below to help reinstall the seals.
and
Okay, all three codes are related to wiring harness issues as they all are saying the PCM is seeing high voltage on the returns from the solenoids. The most likely issue here is a short in the harness. the harness in the pan is common. it is submerged in fluid and over the years it gets into the wiring and shorts out.
Since you replaced all the solenoids, the only thing left is the wiring harness.
You will need to drop the pan again and check the harness closely for any breaks or melted wires.
CHRISTOPHER JARMAN
  • 9 POSTS
Yeah, I got it all in correctly. I followed a step by step video and bought all the right tools. I took my time. I'm replacing the speed sensor now. the only other thing I can think of is the 2-3 shift solenoid, I don't know.
AUSTIN.JENNINGS
  • 5 POSTS
okay, i greatly appreciate all the help Roy. i hope that is what is wrong with it.
CHRISTOPHER JARMAN
  • 9 POSTS
No lights on the dash.
  • 55,748 POSTS
Even though it doesn't have a check engine light it could still have a code. Let me know if the speed sensor fixes it it.
CHRISTOPHER JARMAN
  • 9 POSTS
I ran a code reader, no codes. the speed sensor didn't do it. i'm thinking it's one of the shift solenoids. is there a way to check to see if they are bad before I buy ?
  • 55,748 POSTS
yes, they are a simple. 12 volt ground and power you should be able to feel a click when the circuit is completed. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
CHRISTOPHER JARMAN
  • 9 POSTS
Hard to tell, but that's what it's doing. it will go into the gear but have to let off the gas then it wants to downshift again . but once its in gear and i'm going 40 it will usually stay in 3rd but won't go into 4th. Don't mind the brake light that's my next project, lol.
  • 55,748 POSTS
Thanks for the video. yep, it is not shifting. can I ask did it do this before you did the repair? if so I would try a replacement PCM because if it were a connection problem you would would have a code that pertained to it. Here are the instructions. Check out the diagrams (below). Please let us know what happens.
CHRISTOPHER JARMAN
  • 9 POSTS
It was kind of but when I rebuilt the transmission the third and fourth clutches were toast and the seals were bad. I will check into the PCM. though is there a way to just reset it and see if that works? I don't have a ton of money to just throw at this truck and see what happens, lol.
CHRISTOPHER JARMAN
  • 9 POSTS
Also, when I changed my distributor it did throw out a p034 trouble code and p300. but when I adjusted the distributor it fixed that issue and the code went away. So if it is still able to put codes out does that mean its still working? I don't know. I dislike electronic issues.
  • 55,748 POSTS
I would go back through the transmission then it sounds like you might have folded a lip seal or forgot an o ring. Let us know what happens and please upload pictures or videos of the problem.
CHRISTOPHER JARMAN
  • 9 POSTS
I fixed the issue. turns out it was a the transmission pressure sensor/switch and wiring harness. thanks for all the help :)
  • 55,748 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
