What is the transmission damper torque?
169,000 MILES • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Changing engine so installing old damper assembly on new engine, what torque on these bolts? Please
Aug 8, 2022 at 12:35 AM
  • 110,251 POSTS
As far as the torque is involved, I attached the directions below. The directions include the torque specs.
Take a look at them and let me know if that is what you need.
See pic below.
Aug 8, 2022 at 4:16 PM
BHAMDOC1973
  • 2,007 POSTS
This clutch looking damper is weird, how do i know which side the plate goes as it can go both ways. If this was a normal clutch i would have figured it out.
Aug 19, 2022 at 12:52 AM
BHAMDOC1973
  • 2,007 POSTS
Also, what is the part number for alignment tool?
Aug 19, 2022 at 1:10 AM
  • 110,251 POSTS
The part number for the alignment tool is 09301-00210. I'm not sure I understand your other question. Are you using the original flywheel?
Aug 19, 2022 at 3:24 PM
BHAMDOC1973
  • 2,007 POSTS
Same flywheel, same clutch.
Aug 19, 2022 at 9:16 PM
  • 110,251 POSTS
If I recall, it's the same on both sides. However, you want it the same as it was removed. Are there any bolt marks or indicators on it that would help make that determination?
Aug 20, 2022 at 2:37 PM
