transmission cross-member
189,000 MILES • 3.9L • 6 CYL • RWD
KEVNLKING
  • 26 POSTS
How do you install the transmission cross-member? it is longer than the frame rails. am i supposed to beat it in because i do not have access to a frame spreader? I had to beat it to get it out now i am having trouble installing it.
Jun 7, 2017 at 5:11 AM
  • 55,732 POSTS
Yep the frames can flex inward. We use a port-a-power to move the rails in the shop. This is normal, or you can trim a little off using a grinder.
Cheers, Ken
Jun 9, 2017 at 1:29 PM
