Transmission control sensor an gear ratio incorrect codes
167,000 MILES • 6.6L • V8 • TURBO • 4WD • AUTOMATIC
BARNEY90
I have a 2006 duramax with the 6 speed auto allison transmission.
We have replaced the transmission control sensor already but when I'm driving
It will act like the transmission is slipping and the check engine light come on the codes
That come up are p0700 and p0735? I can reset them and it runs fine for a few miles then
Dose it again but the light don't come on everytime?
Nov 28, 2015 at 10:34 AM
I would start by changing the oil/filter in the trans and inspect the wire harness inside the trans very carefully. it is a common failure
Nov 28, 2015 at 10:40 PM
BARNEY90
Ok thank you. I've been told it's the wiring harness. Another ? Is if the harness is bad will there be transmission fluid in the plug coming out of the transmission?
Nov 29, 2015 at 7:33 AM
yes, that is correct
Nov 29, 2015 at 7:34 AM
