Where is the transmission control module located?
270,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KINGADAM FADDEN
Transmission control module location. Is it and the cou or ECU combined? If so, what does it look like and where is I located? Thank you
Dec 4, 2022 at 11:20 PM
  • 110,248 POSTS
On this vehicle, there isn't a separate transmission control module (TCM). In its place is the powertrain control module which controls the transmission.
The powertrain control module (PCM) is located under the hood next to the battery. If you look below, I attached a picture and highlighted the PCM.
Dec 5, 2022 at 11:09 AM
