The transmissions could have both been the 700R4 transmission. If that is the case, confirm that all connections, sensors, harnesses, and everything appears the same. It should work. However, I can't guarantee it. We only recommend direct fit parts. When you change years, anything could be different.
There were two different transmission used in 1989. They are the following:
3L80/3L80HD (400/475) Automatic Transmission
4L60 (700-R4) Automatic Transmission
To identify the one you have, see pictures 1 and 2 for identification tag information. On the 700R4, trans-axle identification information is found stamped into the case pan rail
Picture 1 is the 3L80 and picture 2 is the 4L60 (700R4)
_______________________________________
Images (Click to enlarge)
Feb 1, 2019 at 7:12 AM
