Transmission codes P1701 and P0826
128,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
COLBSEY
Have two codes P1701 and P0826 come up on a transmission company code checker and they diagnosed it as needing a new transmission. They say you cannot have one rebuilt because none are available for this year of car. No indicator dash lights, just seems like the car is stuck in a manual type mode but the car is an automatic with the manual type gear shifter being the last gear below drive. Car is very jerky and really not driveable. Based on the codes what else can be a possible culprit?
Aug 7, 2018 at 11:30 PM
Good afternoon.
The 1701 possibilities are below.
who is they that you say cannot be rebuilt?? rebuilding is using your transmission.
P1701
Descriptor
Re0F09B
Re0F10A
Probable Causes
Battery Circuit Open or Shorted
Ignition Switch Open or Shorted
Transmission Control Module (TCM) Circuit Open or Shorted
826 possibilities. you need a good transmission shop that will check this properly. from these codes, it looks like you have electrical issues.
P0826
Descriptor
Re0F09B
Re0F10A
Probable Causes
Combination Meter Circuit Open or Shorted
Controller Area Network (CAN) Communication Line Open or Shorted
Manual Mode Position Select Switch In Shift Selector
Manual Mode Select Switch In Shift Selector
Aug 8, 2018 at 7:17 AM
