transmission bolt size and thread size needed
108,909 MILES • 3.0L • 6 CYL • 2WD • MANUAL
ZDZTHATSME
Transmission was taken out approximately 6 months ago. Somehow, they (the bolts) went missing. I have a replacement transmission and someone to put it in but no bolts. I have asked Oreilly, Ford dealership and Napa and have been told basically I'm out of luck. The transmission is a Mazda M5OD R1 5. Can you help?
Regards,
Laura
Jan 13, 2022 at 1:49 PM
Good morning,
There is a place called Fastenal that has nothing but nuts and bolts. They will have the bolts you require for the transmission.
You need 10mm, 1.5 thread pitch by 2 inches long.
Let me know if you have any other questions.
Jan 13, 2022 at 9:43 PM
