Transmission acts like it is slipping
226,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
KODIE WOOD
(This only happens when i turn)
Rather I am at a complete stop and turn or slowing going around a turn. When I go to push the fuel pedal the transmission stalls in neutral then slams into gear hard. I plugged a scanner in and the only codes it brings up is p0442. Which is says small leak in the EVAP. Cannot find the leak. Would a small leak in the EVAP system cause my transmission to do that?
May 4, 2018 at 10:25 PM
Good evening.
No, the 442 is not connected to the transmission at all. it is part of the EVAP system and a smoke test needs to be done to locate the leak.
https://www.2carpros.com/articles/evap-system-code-repair
As far as the transmission, I would drop the pan and change the oil and filter. A clogged filter will cause this issue.
Start there.
May 6, 2018 at 9:35 AM
